Re: Pictures of your battery systems inc. switches/ACRs?
Ok, as mentioned by Silvertip, this is not a switch you keep changing. The only reason you would change from ON to Combine would be because your starting battery was dead and you were wanting to use the house battery to start the engine.
Once you shut the engine off and the motor is no longer charging, the relay opens and all your house functions, electronics, pumps, lights etc. all rely on the house battery, ----- Automatically. The starting battery is isolated from any of the house circuits IF you have the wiring in your boat setup properly. YOU have to make sure none of your accessories are running off the engine harness.
Granted, with only 7-9A output, as mentioned, you may never close the relay. Especially if your motor is hard to start and you have to crank it a lot. But with that setup, even at home on the trailer with a small charger, you can hook the charger up to the starting battery, and with the Battery switch turned to off, you can charge both batteries.
After all that, what motor do you have, and what is the length of battery cables from the switch to the individual batteries?
