Project: River / Flats boat.
jerryjerry05
I guess if I build up the base the 1/2in will work.
​I can get that plywood here in Fl..
​Everything is changeable except the wife's mind.
SkiDad
interesting project Jerry :) looking forward to the finished product
jerryjerry05
You see the pic of the yard sale motor?
​I "might" have to build up the transom a little??
225 Optimax. 30" leg.
Thanks for the "gold"
kcassells
225 Optimax. 30" leg. Nice.... What boat are you going to put it on? That surely be a long shaft.
Holy S Batman....what was that..Oh jerrys Boat going by.
Seriously whats the boat rated for? Pullin my leg areya?
Re: Bayliner 17ft Capri Cuddy 85hp o\b capacity plate
Jerry is probably channeling Frank.....
kcassells
Wow...I checked it out. His name that is. Going...going gone. Out of my league to comprehend the relations.
This is KC signing off. A little to cryptic for me.
Good guess Sam.
sphelps
Well Frank is great source of info an all things Chrysler/Force related ... And he has been known to put big motors on small boats ....
yes, the dear departed Frank Acampora that put a 60hp motor on the back of a 10' long boat. (overpowering by 2.4 x the rated hp)
sphelps
Frank passed away ? I did not know .... I always learned from his post's .. He was a great and valuable member here ...
many months ago. he was a valuable member.
jerryjerry05
No Title
The 225 Optimax was for another project that didn't get done.
About 7 years ago I had a different 21 Bayliner. Same model as I have and use now.
​I removed the twin 85's and put on a 225 Mercury EFI
​The 14ft I'm working on now is gonna keep the 50 that's on there.
​I thought I had more/better pics of the other job?? Guess I can't find them???
jerryjerry05
No Title
The floor of the boat where the old rotten wood is.
They put the battery box under the center. and ran a PVC tube to the back.
​I cut it all down and found a bit more rot in the stringers :(
Not sure I want to go through all the work to fix them??
I used Git Rot on a boat that the motor mounts were rotted out.
Anyone use GR ??
jerryjerry05
No Title
These are after cutting down the bad glass and getting the rotten wood out.
​Pic 1 shows a bit of the transom.
There is a piece(next to the shifter) that connected the transom to the rotten cross piece in the floor.
It's encapsulated rotten 3/8 plywood.
It butts up on the transom.
My first thought was the rot went all the way through and the transom was bad where the rotten wood was touching the transom.
​Even though I tested the transom.
​NOT!!! the transom is solid all the way through!!!
​Mathew caused a bunch of damage here .
My place was saved and lots of branches and trash thrown around.
​Next time I probably won't be so lucky.
