Thanks Joe that's what I've always done in the past. I just purchased a new turning point (hustler) propeller from iboats and it come with a hub kit. The instruction said to use the prop nut spacer that came with the kit and the oem spacer before the prop nut. When installed that way the oem spacer is loose because its not on the prop shaft like with the oem prop. Also I don't think the hub kit is going into the new prop all the way. Seems like it needs torqued to seat it into the prop. I've contacted turning point but no answer back. Thanks.
Is it possible that you either misread the instructions OR the instructions were printed incorrectly, the later case which possibly should have been:
The instruction said to use the prop nut spacer that came with the kit "instead of" the oem spacer before the prop nut.
Using two (2) spacers is not logical to me.
