Re: throttling problem
Did you resolve this issue by setting the "red switch" in line with the cylindrical part of the primer solenoid? If not, you should......there is that little red switch that is on the right side of the motor. right now i have it pointed forward. how i understand is that the red switch is for priming with pull starting. could this switch be a problem?
