bruceb58
- Mar 5, 2006
- 30,772
Re: Welding gurus....advice for a newbie....
Some of the cheaper Lincoln welders, as well as some others, only have a few voltage settings. That is why I like the variable voltage the the slightly more expensive models have. Way easier to fine tune that way with various metal sizes and weld configurations. Problem with the fixed settings is that you have to pull the torch tip away from the work to control the heat which isn't a great way of doing it.A couple of knobs to adjust how "hot" you want to weld (depending on thickness of the metal) and your wire feed speed, and you are off an running.
