haulnazz15
- Mar 9, 2009
- 3,720
Re: WOT, how long is too long to keep 'er pinned?
My concern about WOT isn't as much the engine as the outdrive. Run at normal cruise for 10 minutes and then check the temp of the outdrive (IR thermometer, please). Then go run for 10 minutes at WOT and check the outdrive temp, the temp difference will be significant on most outdrives that don't have a cooler or drive shower (most of them). We all realize the WOT is not "redlining" per say, but the load on the engine in a boat @ 5K rpms is probably more than the load on that same engine in a car at 6K rpms.
I also disagree on WOT being needed for correct plug maintenance for a 2-stroke. Correct air/fuel mixture in the carb at all throttle positions is responsible for that, as well as prolonged idle as most idle settings are a bit on the rich side. If you need WOT to keep your plugs unfouled, you need to see about adjusting your carb to lean it out.
My lawnmower doesn't run at redline, it runs at a predetermined WOT speed, just like a boat. My trimmer generally doesn't see more than 50% throttle unless I'm using the edger attachment, then it gets 75-80% for a minute or two. The blower probably sees the most full-throttle usage, but it's only held there for 15-20 seconds at a time.
