ratdude747
- Sep 30, 2023
- 423
No expert but appears to work. Your sensors are 240-33 ohms and spec shows
Unit switching: Press the button first, then power on, and then enter the parameter selection mode. You can select the 0-190ohm(European) or 240-33ohm(American) level sensor. switch the units of speed (MPH,km/h or knot), water temperature (℉ or ℃) and pressure (psi or bar) with the unit button.
Ah. Noted.
Tracking down a decent (enough) tachometer is proving to be a pain. Most of the stuff that isn't $$$ is all reviews as "leaks water and died" in the reviews. I'd like to have discreet gauges for everything else as I don't know what else worth adding would fit there.
