Re: Cylinders Low In PSI ? (HELP)
The boat ran rough and burned alot of fuel. Was not achieving its speed like before.
Im wondering, what made you do the comp test in the first place? Loss inperformance? Rough idle? And why do you have such big boats? Small boats are simpler. Yes the test with the air compressor will work, what you wana do is get the cyl your testing on tdc or a little past, then when you add air the pressure will rotate the engine over to bottom dead center, to ensure your valves arnt open.
