Re: Glen-L 21' Canyon Cruiser - Aluminum
Ask and you shall recieve..LOL..
Work day 2 - Wednesday night 12/22/10 about 3 hours including clean up.
I cut the transom out tonight. I first double checked my layout and did a couple of diaganol comparisons to make sure that both sides were identical.
The cutting. I bought a non-ferrous metal blade for my Skill Mag-77 and then setup a straight edge with the correct offset. I made the one cut across the the top and it was a bear to keep it running straight. Don't get me wrong, I've framed a ton with this thing but that's what its best at.
I was trying to avoid using my Festool finish saw but I figured what the heck, give it a shot. Yeah, dumb me, there's a setting on it for Aluminum up to 1/2" and I had the right blade but forgot I bought it.
So here it is, the most accurate manual cutting system ever designed. Ya know, if you don't have one of these and you want to build a boat like this, you might consider saving for one. It'll set you back a chunk of change but it's worth every penny.. Here it is. The saw sits on a track and slides. The edge of the track is set dead on the cut line and you litteraly cannot make a bad cut.
Here's an example of how perfect the cut comes out -
Here it is all cut out and cleaned up. I use WD-40 as a lube. It works great and cleans up easier than PAM cooking spray.
I was feeling a little puffed up so I hung the transom on the form. It's just sitting on a couple of drywall screws so it's not exactly square or anything. That will happen later -
One of the things I discovered pretty quick was the amount of chips that fly everywhere. I think I'll put a fresh bag in my dust collector and use it. You can't really sweep the stuff up because it gets all bound up in the broom. A vacuum is the best tool for the job.
Oh yeah, cutting aluminum with the Festool is like cutting butter with a hot knife. I have the plasma cutter and it will come in handy I'm sure but you if you invest that money in a Festool system you'll be better off.
