Re: Glen-L 21' Canyon Cruiser - Aluminum
Thanks for the compliments guy's... You'd be suprised how much things like that contribute to the project
Cutting 1/4" 5052-H32 Aluminum is pretty easy compared to cutting steel. Here's the tools that I've found work the best.
You also want to drill entry and exit holes so you can maximize the size of the left over material. In the end you'll have three good size pieces instead of 6 or more smaller ones.
I've learned to use WD-40 a lot. It will extend the life of your saw blades and drill bits. Although Al is pretty soft, if it gets hot it will clog your bits and blades and render them useless. I've cut out the transom and 4 frames now and I'm on my second blade. You wouldn't get 1/4 of a single frame done if you didn't use a lubricant/coolant of some sort.
I like WD-40 becasue it's easy to clean up and is none penetrating so as long as you do normal prep work for welding you won't have any problems with it as a contaminent. I tested this before I started using it.
Here's a shot of the saw and the cut. Notice the word cut written on the plate. That tells me which side of the line to stay on. If it leave the line on the correct side, I'll always have a little extra material to work with when I fit up. Since it is Al, I could always weld in a little extra material if needed but it's much easier to just knock a little off with the die grinder if I have to.
And here's the entire frame cut out. This takes about an hour to cut with the reciprocating saw. The Festool saw has an adjustable recipricol and varible speed. You kind of just have to play with it to find the sweet spot where the saw dosen't bog or try to run away on you.
You want to have a couple of hand clamps handy so you can clamp the cut portion. I also throw some stickers under it to help support the cutoff piece.
That's about it for cutting out frames. Hopefully you can take advantage of this and save yourself some money buying things like plasma cutters and expensive saw blades. I'll use them I'm sure but I doubt I'll need them to build this boat.
Frame #5 is layed out and ready to cut and then I just have 6, 7 and the Stem (3/8"). The rest of the frames are just more of the same but the 3/8" Stem might be a little challenging so I'll be back when I get to that.
