Sea Rider
- Sep 20, 2008
- 12,345
Re: raising 15hp outboard on transom using wood spacer (with pics)
If the engine is too poor for a given boat, whatever you do, raise engine, play with trim, adding fins, trim tabs, ballancing boat, etc won't make that boat plane. The issue is simple, too much hull drag to overcome with small engine. One thing is trying to plane, other while on plane. Try to get a good Samaritan to lend you a 25/30 HP short shaft engine, more power will guarantee having better hole shot to plane much faster. If that engine is rated for max 50 HP, what are you doing with a 15 ? Once you have installed a larger engine you can fine tune engine/boat configuration. All hull shapes are not same, some has less/more drag.
Owners manual AC Plate heights with respect of boat's bottom is only reference, if wanting boating perfection it's a trial end error issue to find that perfect height engine setting. Get a TT hour/tach, some generic tachs counts double rpm...
Happy Boating
Happy Boating
