platinumedge
- Aug 12, 2018
- 105
I rented a Noid Light set from my local AutoZone and tested all 8 injector connectors. They all appear to be pulsing, as expected; none staying on continuously, none not coming on at all. So, this would seem to confirm that the ECM is functioning correctly. From the results of these tests, I would assume that several of the injectors are "stuck open."
Volvo did NOT employ the pintle system on my particular injectors; "instead, fuel is metered via four small holes in a metering plate on the injector tip." I can see these four small holes, but nothing beyond. Can anyone recommend a method for cleaning these injectors? The body appears to be constructed of a plastic material, so that eliminates certain types of cleaners. I would think that "pulsing" each injector (by introducing an electrical current), and then dipping the tip into a non-volatile cleaner may produce the result I need?? This particular method worked for bringing both fuel pumps "back to life." Ironically, that method may have also loosened the debris in the fuel pumps, and sent them downstream to the injectors!
Best regards to all for a safe and happy Halloween!
