100:1 gas oil mix ( safe for most outboards)If you use the right oil!
kkj
Re: 100:1 gas oil mix ( safe for most outboards)If you use the right oil!
phew, oil certainly make people talk.
TheOilDoc
By LubeDude:<br /><br />Looks like this ones over. All we needed was TheOilDock to cap this one off. ;) <br /><br /> :cool: Looks like rain. :cool:
No thanks. This is just another thread where certain members insist on trying to convince others that Amsoil is the best. <br /><br />As a professional who's tested and certified outboard oils at an accredited facility, my faith in Amsoil ends where they can't certify their oil, yet go ahead and recommend it in TC-W3 applications. Or when they authorize and distribute THESE kinds of misleading sales tactics:<br /><br />"YOU MAY USE AMSOIL SYNTHETIC PRE-MIX 2-CYCLE OIL AT 100 TO 1 NO MATTER WHAT THE MANUFACTURER RECOMMENDS WITHOUT VOIDING ANY WARRANTIES!"<br /><br />I highly suggest members run oil ratios at the manufacturer's specification. They designed, manufactured, and tested the engine, not Amsoil. If 100% synthetic oil is what you want, then use something like THIS that is TC-W3 certified and generally less expensive.
Bwalker
Thats another example of the BS I alluded to in one of my earlier posts.
dakk1
You guys are the best. Reading through this thread is more entertaining than watching a good movie....
cpj
Ensign
Whaley,<br /><br />De CARB ing is not required unless you cook any starchy foods.(ie potatoes) ;)
TOHATSU GURU
Japanese premix two-strokes were actually designed to be run at 100:1...with standard TCW-2 and 3. So that begs the question... Why don't they recommend it? And the answer is...Because it resulted in too high of a failure rate. The extra lubrication value of a 50:1 mix reduced powerhead failures enough so that the manufacturers saved major money and a lot of unhappy customers. There is just no safety margin at 100:1. The slightest rise in heat on that thin of a mix tends to make the engine go boom. Is it safe to run synth at 100:1? I think so. From every reliable source that I have the answer is yes. On a side note, Amsoil has several dullards working there. While they want manufacturers to list their oil as an "approved oil", they are unwilling to supply it for testing. Engine manufacturers have no interest in buying Amsoil to test. From their perspective they would be doing Amsoil a huge favor by authorising it's use. It's a little much to expect them to buy it from Amsoil to test it to compete with their own house brand of oil.
Boomyal
You naysayers can flap your jaws all ya want. In 1979 I bought a new 115 hp 'rude to power my 10 x 30' double deck pontoon boat. I broke it in on dino oil then switched to 100:1 Amsoil. I ran that boat at near full throttle, up and down Pine Flat Lake every two or three weekends from 1979 to 1987. Never changed the plugs, and always started up in the spring on the second try, with no smoke. All my friends would run their batteries down gettin em fired up in the spring and then they'd blow smoke like crazy.<br /><br />That 'rude ran as good when I sold the boat as it did when I bought it.
LubeDude
Originally posted by TheOilDoc:<br /> This is just another thread where certain members insist on trying to convince others that Amsoil is the best. <br /><br />
Hey Doc glad ya joined in so I can poke atcha a bit.<br /><br />Hope its not me you are saying says Amsoil is the best, but it is one of the best, Maybe the best who knows for sure. Ive pretty much been telling people to use the HPI at 50:1.<br /><br />If you havnt tried it and if you havnt tested it, then you should leave it alone.<br /><br />Also, you insist on using that same old Web site to post "Facts" about Amsoil when thats not a quote from Amsoil at all, its a quote from one of those Over zealous Salesman. I told you about that before. Quite using that site as if it were an Amsoil site.<br /><br />Yada, Yada, yada :confused:
TheOilDoc
By member LubeDude:<br /><br />Hope its not me you are saying says Amsoil is the best
Certainly.<br /><br />By member LubeDude (prior post)...."Therefore they use the finest basestock they can find, the best and the amount needed of additives to make the best oil in the world for each application."<br /><br />
By LubeDude:<br /><br />If you havnt tried it and if you havnt tested it, then you should leave it alone.
I'm not sure what your experience is, but for much of my life I tested and certified outboard oils for an accredited laboratory. I have seen what 100:1 ratios, including those of synthetic oils (like Amsoil), do to outboard engines. Our specified TC-W3 testing included a general performance test at 100:1 ratios, a lubricity test at 150:1 ratios, and a detergency test at 100:1 ratios. Outboards were run approximately 100 hours at WOT. Internal engine parts were evaluated under pass/fail criteria. You will see accelerated wear (piston, ring, cylinder, etc.) at these ratios. Possibly failure. This is why I recommend following the engine manufacturer's oil ratio recommendations, not Amsoil's.<br /><br />
By LubeDude:<br /><br />Also, you insist on using that same old Web site to post "Facts" about Amsoil when thats not a quote from Amsoil at all, its a quote from one of those Over zealous Salesman.
That statement is used to sell Amsoil by a dealer authorized by Amsoil. Any oil purchase as a result of that propaganda is routed directly to the Amsoil's corporate website secure on-line ordering. If it's not a quote solicited by Amsoil, then Amsoil shouldn't use it to sell their product.<br /><br />
By LubeDude:<br /><br />Quite using that site as if it were an Amsoil site.
HERE's the site again. One of the most popular Amsoil sites on-line.<br /><br />"YOU MAY USE AMSOIL SYNTHETIC PRE-MIX 2-CYCLE OIL AT 100 TO 1 NO MATTER WHAT THE MANUFACTURER RECOMMENDS WITHOUT VOIDING ANY WARRANTIES!"<br /><br />Again, this is just another thread where certain members insist on trying to convince others that Amsoil is the "best".
kkj
Am I allowed to have a unscientific approach on this 100:1 matter. <br />I am going to make 1 gallon (or 4 litre) of 2-stroke petrol. I have a gallon of petrol in front of me, now I am pouring this little tiny cup (100:1) of oil into the petrol. It looks so little, so unpleasantly little, so scary, so I drop another one so fast I hardly notice it myself. Now I have done 50:1 just like that.<br />What a relief, I feel more comfortable. now I can sleep well, even if I have done wrong.
JB
Gentler than some of TOD's posts, and this time I agree with him.<br /><br />Amsoil probably doesn't deserve to be called Snakeoil, but some of its more enthusiastic salesmen (not including LD) are certainly snakeoil salesmen.
CATransplant
TheOilDoc,<br /><br />I visited that site. Not only is the claim incorrect, but the site is simply a come-on to attract new "dealers" to this guy's downline.<br /><br />I hate MLM. What's being sold on that site is not oil at all. It's dealerships, and each dealer is supposed to find more dealers, and so on, and so on...<br /><br />These guys run their own web sites, and can basically say whatever they darned well please. They aren't going to be the ones fixing the engines.<br /><br />The site you linked to has a little bottle of one oil type pictures, then goes on to say that you can run that oil at 100:1 in every two-stroke engine you have, air-cooled, water-cooled, whatever.<br /><br />Irresponsible.<br /><br />Again, Amsoil products may be just fine. I'll never find out, though. <br /><br />Did I say I hated MLM companies? I thought I did.
ZmOz
I agree with the others. Oildoc, if you're going to be posting "facts" from Amsoil, they need to come from amsoil.com and nowhere else. :rolleyes:
LubeDude
Originally posted by TheOilDoc:<br /> I have seen what 100:1 ratios, including those of synthetic oils (like Amsoil), do to outboard engines.
Like I said, you havnt tested Amsoil, so you have no right to say squat.<br /><br />Besides that I no longer support the 100:1 oils that much, I nearly always steer people to the HPI at 50:1 now that they have it. I do say that the HPI from Amsoil is the best 2 Cycle oil in the world used for TC-W3 aplications. ;) Just because I want to and I can. Can I prove it, ya right. :D
TheOilDoc
By member ZmOz:<br /><br />Oildoc, if you're going to be posting "facts" from Amsoil, they need to come from amsoil.com and nowhere else.
That statement is from one of Amsoil's largest Regency Direct Amsoil Dealers, who Amsoil recommended to me via amsoil.com. So I guess you could say it came from amsoil.com.<br /><br />At amsoil.com Amsoil will help you locate a dealer, just like they did this one. In fact they provide a toll-free number, links to yellow pages, and even a search function via their corporate web site for on-line dealers. You can even find this particular dealer's phone, fax, and location by using the search feature.<br /><br />If Amsoil condoned that statement, which is used to solicit sales of their oil, they would not allow it, or recommend that dealer. It is as much an irresoponsible statement as it is irresponsible for Amsoil to allow it. To suggest that it isn't pertinent because it doesn't come directly from amsoil.com is an excuse for its intention.<br /><br />If Amsoil direct is what you want, then via Amsoil's corporate website at amsoil.com Ed Newman, Marketing and Advertising Manager, writes:<br /><br />"Instructions: SABER Outboard should be mixed with gasoline at 100:1 for normal service in all types of outboard motors"<br /><br /><br />
By member LubeDude:<br /><br />Like I said, you havnt tested Amsoil, so you have no right to say squat.
You're jealous of my expertise. Oil is what I do. I'm an experienced, educated professional who's tested oils most of my life using industry standards and accredited facilities. I have tested Amsoil outboard oils, and I've even run the 100:1 in my own outboards to see what the hype was all about. I am certainly qualified enough to recommend that members do not run them at 100:1 ratios per Amsoil. You will experience premature wear and possibly failure. But do whatever you want LubeDude.
LubeDude
Originally posted by TheOilDoc:<br /> You're jealous of my expertise.
:D :D :D :D :D :D :D :D <br /><br />ROFLMAO!!!
ZmOz
Originally posted by TheOilDoc:<br />So I guess you could say it came from amsoil.com.
No, you can't. :rolleyes: Amsoil cannot control what their dealers say about their oil. We all agree here that most of their dealers and marketing is crap. That fact; however, has absolutely nothing to do with the quality of their products. As I said before, I often use and recommend their products, not because of what dumbass dealer tells me, but from my own experience and knowledge. Yes, the Amsoil 2 cycle oil is a great oil...better than any certified non synthetic. Not at 100:1 though, but the only one here recommending that ratio is the uninformed original poster. Many, many, many people who use and like Amsoil products like I do will tell you not to use it at 100:1. Just because the bottle says that doesn't make it a bad product. It's also good to know that if an accident happens, it will do an ok job of protecting your engine even at 100:1. Not as good as it will at 50:1, but it won't seize up either...
TheOilDoc
By ZmOz:<br /><br />Amsoil cannot control what their dealers say about their oil...the only one here recommending that ratio is the uninformed original poster.
No. Amsoil themselves are recommending that ratio. Again, directly from Amsoil at amsoil.com:<br /><br />"Instructions: SABER Outboard should be mixed with gasoline at 100:1 for normal service in all types of outboard motors"<br /><br /><br />
Originally posted by ZmOz:<br />
Originally posted by TheOilDoc:<br /><br />So I guess you could say it came from amsoil.com
Sure you can. Amsoil directed me right to it; "YOU MAY USE AMSOIL SYNTHETIC PRE-MIX 2-CYCLE OIL AT 100 TO 1 NO MATTER WHAT THE MANUFACTURER RECOMMENDS WITHOUT VOIDING ANY WARRANTIES!"<br /><br /><br />
By ZmOz:<br /><br />That fact; however, has absolutely nothing to do with the quality of their products....Not at 100:1 though...it will do an ok job of protecting your engine even at 100:1.
Then why don't you believe in the quality of their products, and their claims, and run it at the intended 100:1?
ZmOz
Originally posted by TheOilDoc:<br />Then why don't you believe in the quality of their products, and their claims, and run it at the intended 100:1?
Because running at 100:1 with any oil in any engine is silly. It is a stupid recommendation on amsoil's part, but again, it really has nothing to do with the oil itself. I don't use their oil because of anything Amsoil or any dealer tells me. I use it the way I think is best for my particular engine. That is the only way anyone should choose any oil for any engine.
BillP
To each their own but that's kind of weird to me. Amsoil's recommendation has nothing to do with the oil? If they are making "silly" & "stupid" recommendations on ratios then why aren't they making "silly" & "stupid" decisions on makeup & quality of oil made? <br /><br />The only way I choose oil and ratios is by what the motor mfg says to use. I trust those guys more than oil company advertising hype. It doesn't matter what the brand is.
