Jon Sob
Master Chief Petty Officer
- Jun 11, 2011
- 827
Re: 1960's 13' MFG carefree Rebuild (complete noob, i know nothing about this!)
Thanks Boat ...... I started with 2 gal of Poly resin ( make sure that you use the resin without wax or you will have to sand between coats ) because I thought that all I had to do was change the transom. Along the way I found out that my keel was rotted as well so I had to repair that and order more resin. I will have to check and see how much I used all together. One thing that I noticed is that you only have a main stringer. I have a stringer on either side of the main one so you may have to add those to your boat.
Here is what my stringers looked like and they are made of aluminum:
They were bolted to the transom and to the hull with bolts coming thru the keel:
