Re: stuck steering 40hp johnson
yes, the steering wheel did turn, but i clearly remember grabbing a hold of the cable, not the cable housing, an pushing it in an out, and yes the cable housing was moving, but it was moving along with the cable, do u follow?look at the diagram, thats how the cable would move, the part of the cable thats exposed (the diagram of the cable closest to the bottom of the screen) was inside the tilt housing, so in other words, ig u were to grab the cable housing fuacet clamp on the steering cable thats on the diagram attached to the motor,(the highest one) an push on it towards the port, the whole thing will move (cable and cable housing) until its flush with the threaded pipe on the tilt colomn where it goes attached, so im guessing it is broken,but y wont it pull out then?
